Battery Charging Problems?
Old 10-18-2010, 12:14 PM
88Mustang351W
88Mustang351W's Avatar
Originally Posted by enix187
check and see if you alternators (since its good) charge is even making it to the battery, use a volt meter on the two battery post while its running and see what the voltage output is, it should be higher than twelve. If its not then its a wiring problem (since you say the alternator is good) the first thing i would do is open up the wiring harness close to the alternator (its a big one) and find the alternators fuse link and test it for continuity on both sides. If you alternator and battery is are good, and you aren't charging its in the wiring. Its possible when the battery died the first time and you jumped it you blew this fuse link.
When it was running the battery amps were going up to 13 something I really think this is the voltage regulator if my car has an external one but I'm not near it to look at it right now and in the process of finding a ride to go see
88Mustang351W is offline
Old 10-18-2010, 01:00 PM
tua05737
tua05737's Avatar
i just had the same issue this weekend..batteries good..alternators good...my terminals were shot! 6 bucks at autozone took me 15 mins to replace runs like a champ now..maybe that's it
tua05737 is offline
Old 10-18-2010, 02:26 PM
Bubba 95SN
Bubba 95SN's Avatar
You have a IVR(on backside of alternator)Remove covered screw and ground this will full field alternator.(Go to max charge) Check for continuity in output to strter relay.
Bubba 95SN is offline
Old 10-18-2010, 04:41 PM
enix187
enix187's Avatar
its internally regulated, and if you're charging, but it won't support the car start checking grounds, add a few temporary ones to see if it helps.
enix187 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Battery Charging Problems?
