new t-5 need gear help
Old 01-20-2011, 08:38 PM
HaZzArDHD
HaZzArDHD's Avatar
Default new t-5 need gear help
just finished the T-5 auto to manual conversion, the car was an auto so i put in a 4.10 gear but now that the swap is finished i hate the 4.10 its way to much gear for me.
the car is a daily driver so i was thinking about 3.55s but i keep hearing that 3.73s are the way to go in a 5 speed but i fear i will barely notice a difference between the 3,73s and the 4.10.
i want a gear to where i can actually use 1st gear right now it just gets me rolling to around 5 mph or so before i need to shift iv been just using 2nd in its place and it works fine but its annoying for a daily driver/street racer.
any recommendations?
HaZzArDHD is offline
Old 01-20-2011, 08:49 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
3.73's will do the trick, 1st will be good to around 35mph, and you'll deff notice a difference vs the 4.10's
you could always go with 3.55's and build a nasty motor to overcome the gearing ...
sn95_331_GT_ yellow is offline
Old 01-20-2011, 08:54 PM
Bubba 95SN
Bubba 95SN's Avatar
3.73 will work nicely
Bubba 95SN is offline
Old 01-20-2011, 08:56 PM
HaZzArDHD
HaZzArDHD's Avatar
if i went with 3.73s and then in the future built the motor up a bit will i end up in the same boat as i am in now? if that makes since i dont think i worded that right
Old 01-20-2011, 09:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what size tires are currently on the car??
mjr46 is offline
Old 01-20-2011, 11:06 PM
sn95_331_GT_ yellow
no, because a built motor will spin the 6500+, not die off at 5500...
plus at that point youd be looking at a TKO which has a 2.87 first gear, not the T5's 3.35, so 6500/2.87/3.73/815(stock tire size)*60 = 45 is first gear...
just dont go with the .82 5th like me unless you want to be SCREAMIN on the highway lol
Old 01-28-2011, 01:18 AM
stangfreak09
stangfreak09's Avatar
3.73 for sure unless ur like me goin with a 3.90i think it will be a happy medium
stangfreak09 is offline
Old 01-28-2011, 03:43 AM
AdderMk2
Banned
AdderMk2's Avatar
I have 3.73s now and its not enough gear. When I get back home, my car will be getting a set of 4.30's.
the problem you are having is the 3.35:1 first gear. You should have invested in a T5Z or a tremec with a taller first gear.
AdderMk2 is offline
Old 01-28-2011, 11:35 AM
Venomantidote95
Venomantidote95's Avatar
You can compensate with a taller tire. Dosent change the gear ratio but changes the roll out on the tire thus lowering rpms ur engine will turn in each gear to achieve the same speed as a smaller tire!
Venomantidote95 is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: new t-5 need gear help
