timing with supercharge
Ok I have a 306 with a x542 cam, edelbrock heads, trick flow r series and a vortech supercharge with 8-10 psi msd btm retard. What should I set my timing at and the retard boost at.
8-10 base is fine, the btm will pull sufficient out up to 3 degrees iirc per lb of boost on max setting, I'd set the btm at 1.5 to start then lower it until detonation is heard , then you know how low you can't set it..lol
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
