No key start after trans swap? 89' 5.0 GT
Old 08-02-2011, 12:57 PM
wgreenlee4
wgreenlee4's Avatar
Question No key start after trans swap? 89' 5.0 GT
I recently swapped a good 85' T5 for the bad 89' T5 in my current car. The only difference between the two was the neutral safety plug was different. I left the plug on the T5 hanging and then connected the 2 wires inside the neutral safety plug coming from the car (which I read is a work around).
It will not fire from the key but I can pop the clutch or start it from the engine bay.
I am very confused as to what is going on. Anyone have idea?
Thanks
wgreenlee4 is offline
Old 08-02-2011, 02:54 PM
tohoopty
tohoopty's Avatar
mines always just been unplugged and it starts without the pedal being pushed down.try unhooking that wire you hooked up and see if it starts
tohoopty is offline
Old 08-02-2011, 03:56 PM
wgreenlee4
wgreenlee4's Avatar
That did not work for me.
Old 08-02-2011, 07:32 PM
tohoopty
tohoopty's Avatar
have you checked the small terminal on the solenoid to see if its got power when you turn the key forward.ive had that wire lose power before
tohoopty is offline
Old 08-02-2011, 08:05 PM
wgreenlee4
wgreenlee4's Avatar
The small wire running into the solenoid does not get power when I turn the key, I tested it with a multi-meter, I give it power by running a screw driver on it to the positive connection (on the solenoid), that is how I start the car.
Cannibal_carnies
03-02-2023 06:17 PM
djbigskrilla
09-20-2022 01:04 AM
Gary Ugarek
08-26-2015 08:41 AM
Stilz
08-18-2015 09:40 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: No key start after trans swap? 89' 5.0 GT
