Help with high beams
Old 11-15-2011, 06:53 AM
eb2gt
eb2gt's Avatar
Thanks for the diagrams and trouble shooting. I found the problem inharness to multi switch.
For your info that manual shows all the connections, grounding points, color coding, and complete colors of wiring. Very nice!
Thanks again almoststock
eb2gt is offline
Old 11-15-2011, 04:50 PM
fl1a
fl1a's Avatar
I have a 94 GT and an 88 Ford truck with very similar headlight wiring and switch layouts. Each was subject to burned and overheated connections and multifunction switch failure. after having to drive home with the brights on because of a failed multifunction switch, I got a harness to power the headlights from the battery through relays controlled by the original wiring. It was easy to install and eliminated the wear and tear on the vehicle wiring with the higher wattage halogen bulbs available now. Here is a link for the harness I used in my GT...
http://www.amazon.com/Putco-239007HW...1396691&sr=1-1
fl1a is offline
CS2007
06-25-2019 09:45 PM
Drastang
09-30-2015 03:48 AM
mungodrums
09-28-2015 10:54 PM
PNYXPRESS
09-14-2015 09:50 PM
Quick Reply: Help with high beams
