charging problems??
Old 11-23-2011, 06:02 PM
latinmustang90
latinmustang90's Avatar
Default charging problems??
I recently replaced the battery and took the alternator to have it tested and is working normal I check my grounds and my connections look ok .... I also noticed my battery light in the dash is not working either when I open the ignition switch stays off what could be wrong any hints please help.....sos!
latinmustang90 is offline
Old 11-23-2011, 06:15 PM
Bubba 95SN
Bubba 95SN's Avatar
Fusible link or posible the ignition switch.
Bubba 95SN is offline
Old 11-23-2011, 07:00 PM
latinmustang90
the car starts normaly when I jump cables and stays on till it drain the battery out... the only problem is that is not charging everything works like lights, interior lights, power locks, wipers, etc .... the ignition switch is brand new could a fuse link be the cause of the charging issue??
Old 11-24-2011, 08:01 PM
Bubba 95SN
Bubba 95SN's Avatar
veryuseful.com will show what you need.
Old 11-24-2011, 08:26 PM
latinmustang90
is Fix bro thanks for your help all it was is the little circuit board behind the cluster is kind of old is tear in one end thats why I had the charging circuit open but now is working well thanks appreciate
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: charging problems??
