Used AOD not engaging into gear
Old 01-25-2012, 01:29 PM
Shaft
Shaft's Avatar
Default Used AOD not engaging into gear
I guess I get what I paid for. I bought a used AOD that came out of an 88 stang to go into my 93. Supposedly it had been rebuilt a year ago. My mechanic installed it on Monday and told me that the transmission will not engage into any gear. They can shift the lever, plus shift it from the bottom of the car, but nothing happens. Nothing.
I took the original AOD to be rebuilt so I will know that I have a good, working tranny. Did I just get a bad deal on a tranny or is there something simple that is being overlooked? At least I will have a spare core if I need a replacement in the future. Or I may see if the guy rebuilding it wants to buy it.
Shaft is offline
Old 01-26-2012, 04:52 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
The only thing I can think of would be backflushing it but, I believe it has to be able to take reverse to do it. Next one you buy, tell the mecahnic to take the pan off before installing. Dump the fluid and look in the pan for signs.
Anyways, I like the car. I have the same car but, it is a 5-speed.
TrimDrip is offline
Old 01-26-2012, 12:59 PM
mattdel
mattdel's Avatar
Silly to ask, but is the fluid topped off? Your symptoms mirror that of a tranny that has no fluid in it.
mattdel is offline
Old 01-26-2012, 05:04 PM
Shaft
Shaft's Avatar
It was full of fluid and they stopped it off with only 1 quart. The fluid that leaked out of it was clean as could be.
Shaft is offline
Old 01-26-2012, 05:30 PM
mattdel
mattdel's Avatar
K, then I'd say the pump isn't working.
mattdel is offline
Old 01-27-2012, 02:06 PM
Shaft
Shaft's Avatar
Which requires a rebuild, right?
Shaft is offline
Old 01-27-2012, 02:12 PM
mattdel
mattdel's Avatar
More or less. The pump is easy to access, but my thoughts on what is wrong could be wrong themselves. There's Youtube video's about AOD pump removal/inspection, if you're up to the task you could give it a whirl.
mattdel is offline
Old 01-27-2012, 02:26 PM
03gt04mach1
03gt04mach1's Avatar
Also check to make sure the gasket is on the filter housing. And if it is, make sure it's in properly and not torn or offset. An easy check...Pressue Regulator Valve could be stuck OPEN in the Valve Body too. Another thing, the Torque Converter may not be engaged in the Pump Gears.
03gt04mach1 is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Used AOD not engaging into gear
