1991 5.0 Front Wheel play?
Old 07-10-2012, 05:45 PM
BayArea5one0
BayArea5one0's Avatar
Default 1991 5.0 Front Wheel play?
Looking for some advice...my 91 5.0 has some play in the front wheels when she is jacked up and the wheels are in the air. There's not a lot, but definitively noticeable. I'm about to change my front rotors and pads, so I figure I might as well tackle this problems while I'm working on the brakes.
Am I looking at the Inner and Outer bearing's as the culprit? Anything else that is common to cause this issue that I should know about like possibly the Spindles themselves?
Any suggestions/advice is greatly appreciated.
BayArea5one0 is offline
Old 07-10-2012, 05:59 PM
mattdel
mattdel's Avatar
Bearings, ball joints, tie rods, rack bushings, control arm bushings... list goes on. All those can cause play. Need to determine whats moving.
mattdel is offline
Old 07-11-2012, 12:28 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you can adjust the wheel bearings...just follow the proper procedure in the repair manual...
rmodel65 is offline
Old 07-11-2012, 10:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check the wheel bearings, if just loose, tighten them, but not a bad idea to pull and inspect and then clean and repack.
mjr46 is offline
drfister
05-03-2018 10:38 PM
mdj89
08-31-2015 07:27 AM
gus_vb
08-29-2015 11:35 PM
inyadreems
08-21-2015 09:10 AM
Stilz
08-18-2015 09:40 AM
Quick Reply: 1991 5.0 Front Wheel play?
