unable to keep cooling temp down
Old 09-18-2012, 01:00 PM
javila2468
javila2468's Avatar
Originally Posted by Tony71502
Waste of time. These cars should always have a puller fan.
What's wrong with running at normal operating temp? If you are too cold your computer will keep the car computer in open loop.
30 over bore will not make your engine that much hotter. How much have you milled e7 heads? The more you mill heads/block the higher compression will be. Higher compression = higher temperatures.
heads were milled at 0.035. i'm not worried about the computer, i converted to carb.
javila2468 is offline
Old 09-18-2012, 01:02 PM
javila2468
javila2468's Avatar
Originally Posted by dawson1112
what do you have your timing set at. Also you went to a carb so you need to be sure you have the mixture screws set correctly. If you took the carb out of the box and bolted it on chances are your running lean. A lean mix will cause a higher temp.
If you dont like running at 210 get a 180 stat and a 2 core radiator.
Honestly though the stock gauge is crap and highly unreliable for acurate temp readings get a set of after market they are far more acurate.
also you dont need the fan to run all the time they make a kit that you can adjust the temp the fan comes on at.
timing is set at 14*.
@ mattdel, hoses do seem to be a bit flemsy (hope i spelled that right).
I do notice this: if i start the car and let it idle without driving it or putting it underload it will keep temp low but once i drive around the block or put it underload, the temp will rise and will not fall once left idling.
Old 09-18-2012, 01:17 PM
mattdel
mattdel's Avatar
Sounds like radiator to me. A crude way to check would be to take your lower hose off and stick a garden hose in the cap. It should come out the bottom 100% as fast as it's going in.
Given your statement that the radiator is newer, I can't say for certain, though. If it is indeed already plugged, chances are good you need a good hard flush via flushing equipment for the rest of the system.
mattdel is offline
Old 09-20-2012, 07:10 PM
2011scgt
2011scgt's Avatar
if it has no stat there is some of the problem
Originally Posted by mattdel
If you're running no thermostat, an aluminum radiator, and a full-time electric fan, and the engine is still at 210, something is wrong in the cooling system. These engines have a hard time reaching 180 without a thermostat.
Plugged radiator, bad water pump, collapsing hoses... something is wrong.
2011scgt is offline
Old 09-20-2012, 07:12 PM
2011scgt
2011scgt's Avatar
get a 180 stat one with a larger ofice and drill 2 small hole in it...this will help a ton...but these cars really need a 3 core rad,, i put 3 core in all my foxes and no cooling issue period
2011scgt is offline
Old 09-21-2012, 08:25 AM
javila2468
javila2468's Avatar
cooling issue fixed. i had previously removed the aluminum water resevoir it had attached to the radiator but now that i put it back the heating issue went away. i had noticed the radiator would build up too much pressure without it.
BOB ROME
07-26-2023 01:54 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: unable to keep cooling temp down
