t-5 reverse light switch???
Old 05-05-2013, 12:30 PM
GTnotchback
GTnotchback's Avatar
Default t-5 reverse light switch???
I did the t5 swap in my car about 10 years ago. Best thing i ever did. Anyway i have always had a toggle switch to turn the reverse lights on. How can i make it so they operate like a factory t5 car when the tranny is put in reverse?
GTnotchback is offline
Old 05-05-2013, 01:54 PM
mattdel
mattdel's Avatar
2 wire switch on the top of the casing near the shifter.
mattdel is offline
Old 05-06-2013, 05:17 AM
GTnotchback
i know the two pronged switch on the tranny but i dont know how to wire it back into the car to make the lights work when tranny is in reverse.
Old 05-06-2013, 10:24 AM
GTnotchback
do i just plug one of these in and it will work?
http://laurelmountainmustang.com/pro...-light-harness
Old 05-07-2013, 05:19 AM
GTnotchback
nobody knows about this? I have not found a write up that is very clear on this.
Old 05-07-2013, 05:53 AM
dawson1112
dawson1112's Avatar
If im not mistaken the power to the trans switch comes from the turn signal fuse, and the switch just completes a connection to the lights. If you have a ground to the bulbs , then just run a wire that is hot when key is on to the one wire on the switch and the other wire to the hot wire of the bulbs.
dawson1112 is offline
Jb145700
08-21-2022 06:37 AM
2007CalSpec
12-13-2020 11:42 AM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: t-5 reverse light switch???
