Chirping/rhythmic squeaking
Old 06-11-2013, 10:54 PM
Nomansland
Nomansland's Avatar
Default Chirping/rhythmic squeaking
Hey guys, I just bought a 95 5.0 and it started chirping/squeaking in a rhythmic pattern, it's not the distributor I don't thing, and its not the belt. I have already tried holding the distributor down, and oiling the pulleys/ belt dressing the serpentine belt. It sounds like the noise is coming from somewhere in between the distributor and the intake manifold but I can't really pinpoint it. The noise gets faster when the rpm's go up. Please help me fix this problem.
Nomansland is offline
Old 06-12-2013, 03:27 AM
dawson1112
dawson1112's Avatar
Its likely a bearing on one of the pulleys such as the alternator , smog pump, water pump, idler etc. Coming from the location you indicated likely to be the idler pulley or water pump.
dawson1112 is offline
Old 06-12-2013, 10:03 AM
big ben
big ben's Avatar
take the belt off check each pulley for bearing slop and noise then start the motor with the belt off if the noise is gone put the belt back on get a long scew driver or pry bar and listen to the end of it while you touch the bolts or brackets of the pulleys and water pump housing
big ben is offline
Old 06-12-2013, 03:24 PM
Nomansland
Nomansland's Avatar
Thanks guys. Also, I forgot to mention after I really get on it, it won't go into reverse. If I drive normally and don't hot rod it, it usually goes into reverse fine. But if I drive it like I stole it, after it's like reverse is non existent. Any ideas?
Old 06-15-2013, 06:59 AM
wydopnthrtl
wydopnthrtl's Avatar
Noise = first two posts were right on the mark.
When the bearings are going out it's not uncommon for them to not make noise when first starting, make growling noises, or chirps. (chirps = dry bearings)
Tranny = Sounds low on fluid to me.
wydopnthrtl is offline
Old 06-16-2013, 05:16 PM
Nomansland
Nomansland's Avatar
I put the car up on the lift and turns out a pulley was rubbing up against a cluster of wires cased in a plastic housing. Chewed right through it, thanks guys. Just happy it wasn't bad bearings.
istambay1217
06-30-2018 12:31 PM
marcuslee842
06-04-2005 05:02 PM
StngPshr03
04-26-2005 06:42 PM
Cedarkill
09-14-2004 08:35 PM
EmptyEvergreen
09-03-2004 03:40 AM
Quick Reply: Chirping/rhythmic squeaking
