Will bigger flywheel fit old starter?
Old 07-23-2013, 03:22 PM
wgreenlee4
wgreenlee4's Avatar
Default Will bigger flywheel fit old starter?
So I had my old flywheel machined, and then I installed it yesterday with Loctite only to find that my new 10.5” clutch and pressure plate does not fit it. I now realize that my old clutch was actually only a 10” clutch, that came with a smaller flywheel. Which is weird considering that the engine is a post 1985 5.0 (fuel injected). So I ordered a standard size flywheel to go with my standard size clutch (10.5). But I just realized a problem; will the new flywheel fit the old starter? Won’t it not? Because if the flywheel is bigger, the new starter should run into it. What do I do about this??? Help!
Thanks
wgreenlee4 is offline
Old 07-23-2013, 03:42 PM
Tony71502
Tony71502's Avatar
Someone will correct me if I'm wrong, but I think the difference in the flywheel size is in the surface where the clutch contacts the flywheel. The outside diameter, tooth count and whatnot is the same.
Considering you already ordered it, compare them when it arrives.
Tony71502 is offline
Old 07-23-2013, 06:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'll have no issue, tony is correct!
mjr46 is offline
Old 07-26-2013, 09:13 PM
wgreenlee4
wgreenlee4's Avatar
You guys were right! It was the same size and the clutch bolted on nicely.
Thanks!
jwog666
12-27-2021 08:09 PM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
junior04
09-28-2015 10:53 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Will bigger flywheel fit old starter?
