Passenger door clock problem/ cd head unit issue.
Old 02-25-2014, 01:21 PM
IvanFiveLiter
IvanFiveLiter's Avatar
Default Passenger door clock problem/ cd head unit issue.
Just recently the passenger side door handle has not been opening the door but instead having to unlock it from the outside or the passenger opening their window and opening it from the outside (1990 gt). Any specific things i should know before i pull the door panel off to see whats wrong? Also my cd has been stuck in the radio and will not play nor will it eject the cd. Could this be the head unit malfunctioning or is it an electrical issue?
IvanFiveLiter is offline
Old 02-25-2014, 02:08 PM
88 orangepeel notch
88 orangepeel notch's Avatar
Sounds like your going to have pull the panel off, broken latch or the rod came off. And if your headunit has power, and not ejecting the CD, that would have nothing to do with the car. Good luck
88 orangepeel notch is offline
Old 02-26-2014, 10:34 PM
bruehlc
bruehlc's Avatar
My grandma had her favorite cassette stuck in her stock buick for like three years before I had to put a new unit in. Never got that tape out (ha ha).
Also, the door rod clip most likely broke so get that panel off and find out if it will just pop in or if you have to go to latemodelrestoration.com to get some new clips. They do break easily over the years.
bruehlc is offline
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Passenger door clock problem/ cd head unit issue.
