How to Tighten Stock Rockers
Old 05-12-2014, 06:54 AM
yurizx6r
yurizx6r's Avatar
Default How to Tighten Stock Rockers
Hey guys, I know this is a simple and dumb question, but I just wanted to double check before I put my car back together. Long story short, I advanced the timing on my timing chain 4 degrees and for whatever reason, I bent every push rod on the intake side (yes I put the timing chain at TDC when I did it). Either way, now I've got the chain back to stock and need to swap out all the rods and roller lifters. I have the car apart and just wanted to double check that since it's the stock rockers (with a bolt over a stud and nut) all I do is just torque the bolt down with torque specs correct!? Also, once I put the roller lifters back in the car, I don't have a certain amount of time until I have to start the car right? I've had them soaking in oil for 4 days and I plan on putting some engine assembly lube on them before I put them in. Thanks for all your help in advance!
yurizx6r is offline
GPR
12-16-2015 12:21 PM
uedlose
09-30-2015 08:01 AM
JDWalton
09-24-2015 08:47 PM
mikesr4565
Suspension
09-21-2015 10:26 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: How to Tighten Stock Rockers
