Kaase P-38 Heads
Old 01-02-2015, 01:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you have to use those heads to make power on a turbo build.....something is wrong......I know a guy with afr 185 heads and a turbo running 8's.......
mjr46 is offline
Old 01-02-2015, 02:59 PM
barnett468
barnett468's Avatar
Originally Posted by 84CopperGT
Yes, they flow more, but it's more about velocity with a turbo. This isn't the first turbo car I have built, it's just going to take the longest.
Where did you see velocity specs for all these heads to be able to compare them with each other?
barnett468 is offline
Old 01-03-2015, 02:49 AM
84CopperGT
84CopperGT's Avatar
I'm trying to make power off boost, not just on boost. I could boost the life out of an engine if I wanted to, but I want something that can actually be driven everyday, low boost, and make plenty of power when I want the power. Not like my last car where I had to build boost at the line or shift WOT to keep boost.
84CopperGT is offline
Old 01-03-2015, 02:52 AM
84CopperGT
84CopperGT's Avatar
Stock engine made 500 at the flywheel with only top end work.
http://www.mustangandfords.com/how-t...ylinder-heads/
Old 01-03-2015, 08:48 AM
mjr46
mjr46's Avatar
http://www.theturboforums.com/ go learn something
mjr46 is offline
Old 01-04-2015, 03:07 AM
barnett468
barnett468's Avatar
I can't get your link to work either.
Old 01-04-2015, 08:47 AM
uedlose
uedlose's Avatar
Get them and let us know how they work for you.
uedlose is offline
Old 01-05-2015, 02:49 AM
tinman
tinman's Avatar
Couple of things here.
Those Kaase heads are intended for very high output N/A engines only, also very expensive for what you get IMHO.
Also, whoever said that Edelbrock VicJR. heads were pedestal mount type is full of it.
Mine sure aren't......
tinman is offline
Old 01-05-2015, 11:13 AM
84CopperGT
84CopperGT's Avatar
I talked to Jon Kaase on the phone the other day. He said the same thing but he also was saying that a few of his customers put them on boosted cars and made better power through the entire powerband. Now, people will hype up their own stuff to sell it, however, most won't lie because the word always gets around. So I am going to order a set, slap them on a 363, and see what happens. Then, I guess i'll pump 10 PSI through a turbo further down the road. Now to get that raise at work and get my tax return.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Kaase P-38 Heads
