single or dual plain intake and cam recommendations
Old 12-27-2015, 08:41 PM
jrp79
jrp79's Avatar
Default single or dual plain intake and cam recommendations
91 gt 306 5 speed going carb.got a few questions. current set up is 306 roller block, stock e7 heads(for now).trick flow cam, bbk unequal length shorty headers going into a 3" off-road xpipe into 2.5" flowmaster cat back.
Im use to dual plane intakes but was looking at the parker funnel web, would it be a good choice to get a intake like that or stay with a 1500-6500 dual plain? I know single plains are good for top end but would I still be able to punch 1st gear and smoke the tires?
also what cam would be a good choice for my set up.i heard Anderson's cams are good but I was looking at the specs of the frp x-cam and seemed good for me
jrp79 is offline
Old 12-28-2015, 08:11 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I'd wait till you upgrade the heads before doing an intake swap. No matter what intake is on it......., the heads are only going to flow so much air.
88 orangepeel notch is offline
Old 12-29-2015, 09:12 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's all about the combo..........throwing in the x-cam will do nothing for you but make noise............you need to get with this guy www.flowtechinduction.com
mjr46 is offline
Old 01-04-2016, 12:29 AM
Richard1916
Richard1916's Avatar
offenhauser 5493 good hood clearance , not really a single or dual plane ,technically it is dual but unlike most others it feeds left right not inner outer . funnelweb looks awesome but need compression and more cylinder head.
I ran offy with f303 and 750 holley double pumper, pretty good torque, great throttle response perfect for a manual car
Richard1916 is offline
Maine-iac
03-11-2016 01:06 PM
Matthew McEldowney
11-20-2015 02:53 PM
Tony Iocca
11-05-2015 10:53 AM
_Remi
10-27-2015 01:01 PM
Quick Reply: single or dual plain intake and cam recommendations
