BBK SSI Intake Question
Old 03-23-2007, 09:30 PM
8950lxstang
8950lxstang's Avatar
Default RE: BBK SSI Intake Question
No one should ever buy a BBK SSI intake. It is the biggest piece of sh#t i have ever owned!!!!! I rebuilt my engine back in spring of '05. Bottem end is built to stock spec, have an f303 cam, gt40x aluminum heads, new lifters, FRPP 1.6 roller rockers, 24#injectors, 65mm TB, 75mm maf. Not only did i have to wait 6 months to get that intake back then, u have to modify all kind of sh#t for it to work. With the motor in the car the upper plenum hit the firewall and didnt sit flat on the lower. U have to relocate the BAPsensor(MAP sensor on speed density cars)and move the main wire harness up cause the intake rubs against it when the motor when it shakes. I finally stretched the firewall and got it together. Drove the car for a week and end every time i started it it smoked like a damn diesel. Pulled the top cover of the plenum and it was full of motor oil that the pcv sucked in from the lifter valley. I unhooked the pcv and cleaned the oil out of the plenum and it stopped smoking but still ran ****y with a rolling idle and and only about 15in. of vacuum. Found2 holes in the casting of the upper plenum and bird **** weld inside around the throttle body opening. Needless to say im buying an edlebrock right now!
8950lxstang is offline
Old 03-23-2007, 09:55 PM
gearbanger
gearbanger's Avatar
ok i member that in mm&ff they had a issue on that......tfs made the least power over the rpm2 and holly........ it was tested on a 347 i think the rpm2 came in first then holly, and trick flow
gearbanger is offline
Old 03-23-2007, 11:13 PM
5pointslow91
5pointslow91's Avatar
Even though it is pretty tall, i was told that it would fit under a stock hood, because i was looking at them myself but then decided the get the holley
5pointslow91 is offline
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Luke9222
09-04-2015 06:46 AM
09-01-2015 08:16 PM
Quick Reply: BBK SSI Intake Question
