yes i looking into getting AFR heads for my 347 stroker and i was wondering if there any good, and if anyone knows which AFR heads i should go with, my car is goin to be around 375-400hp
no smaller than 185's and yes they are decent heads, I run them on my 347, If I had the money and were to do it again I'd run either the tfs fast as cast head or a high port
I have the 185 on my 347 as well, good stuff, yet I had to upgrade the calve springs right away as they only support .500" of lift...and if you do that too, make sure you change the valve seals to the smaller style as well.
