a few questions for a '83 mustang
a couple things you can try.... the big thing is have the timing as low aspossible... try it at 8*, stock is 10* but if it's close they might let it fly.
then make sure it's hot, run it hard w/ the AC on to make it as hot as possibe
also use the "guaranteed to pass" from kragens or wherever you go
read the instructions and do what it says
you should be ok
does the car have cats ??? is the exhaust stock ?? should be 2 precats and 2 cats i think it's like the newer ones
you should be ok
'83 came stock with a y-pipe from the headers to a single exhaust pipe, and it does have the cat for the single pipe. i'll do what you suggested and give everything a good look over to make sure everything is connected and stuff.
Diode Dynamics
28
05-26-2022 12:02 PM
