Posi track
Old 11-13-2010, 11:15 PM
Dinstaar
Dinstaar's Avatar
Default Posi track
Hello,
I am wanting to put a posi track rear end in my 89 5.0 fox. Does anyone know which vehical rear ends would work for this conversion? Thank you
Dinstaar is offline
Old 11-13-2010, 11:26 PM
AdderMk2
Banned
AdderMk2's Avatar
putting a chevy rear end in your car is probably not going to be done easily.
However, there is a solution! Your 89 (assuming it was originally a 5.0 car) comes with an 8.8" Traction Lock style limited slip differential. Your clutches are probably worn out and in need of replacing.
The rebuild kit is about $100
google search: trac-lok rebuild
AdderMk2 is offline
Old 11-14-2010, 02:17 AM
tohoopty
tohoopty's Avatar
lol adder
tohoopty is offline
Old 11-14-2010, 07:38 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if it's an 8.8 op, as stated it has what you call "posi" or for a ford the correct term is traction-loc/limited slip
mjr46 is offline
Old 11-14-2010, 12:39 PM
Bubba 95SN
Bubba 95SN's Avatar
Sounds like you need to put new clutch packs in the rear.
Bubba 95SN is offline
Old 11-14-2010, 02:26 PM
Bobert
Bobert's Avatar
+1
I wouldn't replace the entire rear end just rebuild the carrier in your current rear end. Much cheaper and less hassle. Possibly replace gears while your at it.
Bobert is offline
cr620
10-03-2022 10:18 PM
88 orangepeel notch
10-05-2015 09:03 AM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Posi track
