5.0L V8 Identification?
Old 07-23-2013, 08:32 AM
zeroroadkill
zeroroadkill's Avatar
Default 5.0L V8 Identification?
Can you identify this 5.0L V8. May be a 1994?
Thanks
BOBB
zeroroadkill is offline
Old 07-23-2013, 09:11 AM
dawson1112
dawson1112's Avatar
The block could be any year 5.0 absolutely no way to know with out id # on the block... the upper intake is from a 87/93 5.0ho and from the looks of they have done the reversal of the intake , there are some reasons that some pple do this reversal usually to make room for a turbo, or ease of throttle linkage adapting.
dawson1112 is offline
Old 07-23-2013, 09:30 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
awww come on you can do better than that on the year^^^^^^^^^^ there is one key identifier that eliminates 89-93, not to say the long block isn't one of those years but since there is an air filter right off the throttle body, it's a Speed density set up so 86-88 would be most likely Key is, there is no mass air from what I see in the photo. but could even be a crown vic motor since the intake is flipped, can't remember if the lincoln mark 7/8 had the intake flipped as well, and they were h.o motors as well
mjr46 is offline
Old 07-23-2013, 09:46 AM
Tony71502
Tony71502's Avatar
That's a weird EGR spacer. I thought the coolant ports were on both sides at the top. Does that help ID it?
Tony71502 is offline
Old 07-23-2013, 10:54 AM
zeroroadkill
Interesting, the owner says it might be out of a 1994 Lincoln, he doesn't really know! I'll try and get the engine ID number off the block on Friday.
Thanks
BOBB
Old 07-23-2013, 11:09 AM
dawson1112
dawson1112's Avatar
Thanks
BOBB
I would go with Lincoln also because they did have the ac compressor on the opposite side and the intake was opposite of the mustangs as well. But the 94 mark viii, and towncars had a 4.6l not a 5.0. 86 Lincoln town cars used a 5.0l engine with the intake flipped like that. Judging from the location of the ac compressor that's what I would guess to say it is, but you never can tell what was done to the engine to make it fit in that bay.
mattdel
08-23-2022 12:42 PM
82GTdriver
10-24-2008 09:39 PM
Quick Reply: 5.0L V8 Identification?
