AmericanMuscle.com Premier store carries over 1000 Mustang parts and accessories. Features the largest mustang wheel selection available and offers free mount and balance with tire purchases. Committed to expert customer support, great prices and fast, free shipping!
Oil separator rubber seal question
Old 08-26-2015, 08:26 AM
jesse1125
jesse1125's Avatar
Default Oil separator rubber seal question
I was wondering if the rubber seal for the canister is a common O ring that you can get at a home improvement store? The reason I ask is because to check how much oil is in the canister you have to remove the canister. I'm sure in time the rubber o ring seal would eventually need replace from being squeezed each time you put the canister back on. If you pinch it or tear the rubber you can develop a vacuum leak so keeping a good seal would be important and having a replacement on hand would be needed.
Thanks
jesse1125 is offline
Old 08-26-2015, 10:16 AM
Urambo Tauro
Urambo Tauro's Avatar
I want to say it's rubber. I think the AC lines are the only ones that take special o-rings. To avoid tearing them up, you can apply some petrolem jelly (Vaseline) on them to make them slide easier.
Urambo Tauro is offline
Old 08-26-2015, 12:11 PM
Phillip123
Phillip123's Avatar
Yeah it may be rubber. If that's the case petrolem jelly will do the trick.
Phillip123 is offline
Old 08-26-2015, 01:51 PM
AMAlexLazarus
Former Sponsor
AMAlexLazarus's Avatar
Hey Jesse - Just like what's been said here petroleum or any type of generic grease/lubricant that can be picked up at a local parts store should do the trick perfectly.
Alex
AMAlexLazarus is offline
Old 08-26-2015, 02:34 PM
jesse1125
jesse1125's Avatar
Has anyone ever had to replace the canister seal and if you did where did you get a replacement? Being made of rubber it's not going to last forever.
Tivo304
08-28-2023 12:19 PM
bjdutch2005
03-24-2017 03:38 AM
Roush05
09-10-2015 12:23 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Oil separator rubber seal question
