Looking at the AVH-P3200
Old 12-25-2010, 11:47 AM
xenocide
xenocide's Avatar
I just ordered this and it should be here on the 30th. Does anyone know what wiring harness is needed? 2011 base v6. thanks.
xenocide is offline
Old 12-25-2010, 07:00 PM
Xeno
'Dr. X'
Xeno's Avatar
according to crutchfield, it looks like you'll need the same pac harness (http://www.amazon.com/C2R-FRD1-Radio.../dp/B0015ASMIQ). i'm planning to make an install write-up for this, and i should be installing it in a day or two; it shouldn't be complicated to do, though... basically match the same colored wires together
Xeno is offline
Old 12-27-2010, 01:54 AM
xenocide
xenocide's Avatar
Thanks Xeno. ugh so expensive. let me know when you've done your write up.
xenocide is offline
Old 12-27-2010, 10:52 AM
Xeno
'Dr. X'
Xeno's Avatar
that's actually ~ 1/2 of what crutchfield/bestbuy/etc charge, so even though is looks expensive, it's still a steal .
also, i installed the radio yesterday... and everything is working as it should (for the moment, at least ), so i should have the write up completed in a day or two. it was actually easier than i thought it would be, too.
Xeno is offline
Old 12-27-2010, 12:05 PM
xenocide
xenocide's Avatar
Congratz. How is it?
xenocide is offline
Old 12-27-2010, 09:28 PM
Xeno
'Dr. X'
Xeno's Avatar
so far so good, i've been playing around with it a little (kind of cool playing a dvd in your car ). i'm kind of an audiophile, so i've been dinking around with the equalizer, but regardless, it sounds much better than the shaker headunit; i can hear more midrange, which is something the shaker was lacking
Xeno is offline
Old 12-28-2010, 04:57 PM
allinon72
allinon72's Avatar
No need to spend money on that PAC harness...just splice in a 12v resistor for the amp turn on and you're set.
allinon72 is offline
Old 12-28-2010, 08:15 PM
Xeno
'Dr. X'
Xeno's Avatar
write-up is completed:
https://mustangforums.com/forum/audi...ml#post7350332
Xeno is offline
Xeno
04-03-2020 08:29 AM
Quick Reply: Looking at the AVH-P3200
