460 heads
RE: 460 heads
a larger cc will give u a lower compression, larger valves will flow better . Go with the 460 performer heads from edelbrock that have a 95 cc chamber and i think u shouldn't need any more. They have a 75cc as well, but i don't know your plans with the engine.
RE: 460 heads
Whats the 460 going in?
Whats the intended usage? ie drag car, street strip, daily driver, etc.
Whats the cam and intake you plan on running?
What gears will it have?
How much are you willing to spend to get what you want?
What exactly do you want from it?
RE: 460 heads
right now i only have the block its a eliminator premier its gonna go in a 67 or 68 coupe after i find one with a good body cheap im gonna drive it daily im gonna try for the max hp on pump gas i can price doesnt matter i did find a company that remakes the boss 429 heads they are stuck in my mind
RE: 460 heads
RE: 460 heads
ORIGINAL: Brandontyler65
if you are gunnna get 460 heads then get cobrajet or supercobrajet and also use the pre-71 timing set on your block and if you want more just buy the 514cid kit for that block
x2 and the 514 shortblock from Summit is $3500. Add a cam, heads, intake, other externals and you are there.
RE: 460 heads
breaking
10-02-2015 01:27 PM
