dashboard removal
RE: dashboard removal
Let's get our terminology straight. The dash pad is the soft vinyl thing that is on top of your dash. Your dash is welded to the frame, and not going to come out. Taking off the dash pad will do nothing to help you get to those wires. You just have to rewire it with the dash on.
So you guys are telling me that the only way to get to the wiring is to remove the instrument cluster? That seems like an awfully small hole to work with. I guess you get what you get. Oh well. Thanks.
oh yeah, and depending on the type of seats you have bucket/aftermarket/bench, you may want to remove those too. I have a bench in the front, so I kind of lay on that to get under the dash to any wiring I can't see from the dash, last time I did work under there I removed my shifter to give me a little more wiggle room.
jwog666
12-27-2021 08:09 PM
