'69 wheel/tires
RE: '69 wheel/tires
the wheels will work fine, but the 50s might be too wide for the 8" rim. better either get a 10" rim or go with a little narrower tire. another thing! i had 10" rims with 295-50s on the back of this 69 and i had to use air shocks to keep them from rubbing.
RE: '69 wheel/tires
Don't worry to much about the number on the sidewall....worry about where the rubber meets the road.
Sure...the 275 looks fatter than a 255....
http://www.dodgestang.com/DR/275-3.jpg
And has a wider section width
275: http://www.dodgestang.com/DR/275-4.jpg
255: http://www.dodgestang.com/DR/275-5.jpg
But you are sacrificing it all when you put it on an 8 inch rim
275 on an 8 inch rim contact patch about 8 inches:
http://www.dodgestang.com/DR/275-18.jpg
255 on an 8 inch rim contact patch........about 8 inches:
http://www.dodgestang.com/DR/275-19.jpg
The only reason I have a 275 mounted on a 8 inch rim, is becuase I know it 'shrinks' the section width slightly on an 8 inch rim and on the 65/6 mustangs there is not alot of room and they are drag radials so I get the sticky compound benefit (I also get the tires for a song )
RE: '69 wheel/tires
ORIGINAL: jkentjr1
Thanks, did the 275's on the 8 inch rim rub your Mustang anywhere...any need to roll the fenders?
