Coolant leaking from back of motor
I'm loosing a ton of coolant from somewhere near the back of the motor, haven't had a chance to pinpoint the cause yet but I can see it pouring out all over the transmission when the car is running. What are the most common areas that can fail back there?
RE: Coolant leaking from back of motor
did you just replace the heads/intake, if heads did u use new gaskets, if intake ame thing, plus did u use the cork ends or a bead of silicone, if nit, take the intake off and see where its comign from.
Check the back the intake. Mine leaked there due to a bad seal. Also check the heater hoses. I had a connection between my heater hoses making them two pieces instead of just one full hose. It leaked at that connection, so I just unhooked and plugged the heater hoses. Cleaned up the engine compartment also.
soulcaliber39
12-28-2016 04:57 AM
91StangOwner
08-20-2015 11:34 PM
