Welder
Old 12-06-2006, 03:07 PM
67Stang68
67Stang68's Avatar
Default RE: Welder
+1 on the Lincoln 135 , I have that one and its quality is excellent. Its not the one from Home Depot, they dont have
an infinite power setting (rheostat switch) The one from HD click-click-click. The infinite switch gives you more flexibility.
67Stang68 is offline
Old 12-06-2006, 03:21 PM
supermanzx9r
supermanzx9r's Avatar
Default RE: Welder
some of us will only use it only once or twice , yes a person can spend more money for better quaily but that is only if you plan on using it alot
supermanzx9r is offline
Old 12-06-2006, 03:24 PM
Shifty101Easy
Shifty101Easy's Avatar
Default RE: Welder
i plan on patching a few holes....so its probably good, right?
Shifty101Easy is offline
Old 12-06-2006, 03:30 PM
supermanzx9r
Default RE: Welder
yes
Old 12-06-2006, 03:53 PM
Shifty101Easy
Default RE: Welder
is there a good chance they will have this in stock at the store or should i order it online?
Old 12-06-2006, 03:58 PM
supermanzx9r
Default RE: Welder
call the store there number should be on there website
Old 12-06-2006, 04:40 PM
THUMPIN455
THUMPIN455's Avatar
Default RE: Welder
Shifty, just dont expect to be replacing everything with it. Havent used one, and you know my feelings on HF, since everything I got from them has broken on the first or second use.
If it works, you can probably get the floor pans done with it, and plug a couple holes. Working with outer sheetmetal, like quarters, fenders doors, etc, having a good welder makes a huge difference. I have the lowest cheapest Hobart that uses gas, because I was mobile with limited storage/work space in the USAF when I bought it. it works, but filling in the holes for my vinyl top is a pain with it. Especially compared to the one my dad has, its a 220v Lincoln that has every possible setting and can weld 1/2" thick plate, or 20 guage sheet. Filling holes with his is easy, simple and fast. Mine is much more labor intensive.
yes it should work for a small job or two. Just dont try to do anything huge with it, ok? it probably wont live through it. Fires are not a good thing. I doubt my little hobart will survive the Mustang, and the 65 GTO would kill it for sure.. too much rust.
THUMPIN455 is offline
Old 12-07-2006, 12:29 AM
deebo68
deebo68's Avatar
Default RE: Welder
Harbor Freight sells junk, yeah you save some money up front, but it won't last. I use a Hobart 135 with gas and flux. It was about double the price of a cheap flux welder, but if you have to buy a cheap welder twice then you should have saved up for a decent welder once. Also, you might want to tackle some tougher jobs in the future and having a gas welder is a nice option.
Don't forget the mask, the auto dimming masks are great, Hobart sells a nice entry level mask for about $100. Worth the money!
deebo68 is offline
Old 12-07-2006, 01:03 AM
sweet 65
sweet 65's Avatar
Default RE: Welder
Don't buy that welder. For the cost of that thing which might work for a little while in your inexperienced hands you could take it and have a professional do it. The work would turn out much better and you wouldnt have money into the mask and gloves and everything else you need to do a good job. You should either get something worth while in long run or nothing at all. I would stay away from harbor freight unless you are looking for disposable hand tools. It seems like everything they sell is disposable, even welders now. Use the money to buy something that will last.
sweet 65 is offline
bradleyb
11-04-2006 01:26 AM
atomsk680
07-23-2006 02:02 PM
6mustang6
06-09-2006 02:45 PM
charged90lx
01-03-2006 06:47 PM
mustangdemon01
10-11-2005 10:42 PM
Quick Reply: Welder
