need brake light advice
my left brake light does not function. both rear park lights work and both the left and right turn signals work fine - its just that the rear brake light will not come on when i mash the pedal. i have changed bulbs and swapped bulbs...so that's not the problem. could it be the switch on the pedal or is it the wiring?
RE: need brake light advice
If the right light works it would not be the pedal switch etc. There is probably a jumper from the right to left side that is bad. Like the otthers mentioned grab a meter or test light and check the socket itself, could have some rust in there losing the connection.
