Brake Line Question
Brake Line Question
i was going to splice into my brake line to install a proportioning valve and was wondering if anyone else has done this. i was told that you couldnt cut and double flare stainless steel lines because its too hard but when i called around people didnt seem to have a problem with it. so i wanted to know, can i do this or do i have to figure something else out?
RE: Brake Line Question
It is hard to work with. Double flares are hard to do with regular steel. I would not waste my time with stainless.
You should avoid splices if possible and use a continuous line. I have used compression fittings in the past but this may not be legal in some states.
