Brake lines
Old 06-12-2007, 11:36 AM
dnswwood
dnswwood's Avatar
Default Brake lines
Does anyone know of anyplace that sells a complete brake line system from the master cylinder to all four wheels with the proportioning valves and everything in the kit for a 70 fastback? I can find them seperatly but thought it might be easier and or cheaperto order a whole "kit"
Thanks for any info
Jeff
dnswwood is offline
Old 06-12-2007, 11:43 AM
dozierstang
dozierstang's Avatar
Default RE: Brake lines
I ordered a complete stainless set from Laurel Mountain Mustangs. Had everything but the flex lines (going to to calipers and the rear) and proportioning valve. Most if notall will sell those individually.
Oh, forgot to mention. Once you buy a non-original set of these, it will take some finagling to get them to fit. So don't expect a perfect fit.
dozierstang is offline
Old 06-12-2007, 12:33 PM
eholzer07
eholzer07's Avatar
I just went to NAPA and bought the brake lines myself. It was a TON cheaper than ordering the pre bent. and you can buy a bending tool for like 5 bucks
eholzer07 is offline
Old 06-12-2007, 12:43 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: eholzer07
+1 I was just going to suggest that. Another benefit of going this route is you can make the lines fit better than most of the aftermarket ones since you make the bends.
Derf00 is offline
Old 06-12-2007, 12:50 PM
RGH69
RGH69's Avatar
Also, an easy way to do it is to buy some cheap stiff wire such as electric fence wire. Then use the wire to test the routing and the bends. Then use the bent wire as a template for making the bends needed in the brake lines.
RGH69 is offline
Old 06-12-2007, 01:00 PM
solidGas
solidGas's Avatar
I just installed all my line and I ordered the pre-bent lines from NPD. The front driver side was to short so I had to buy a new line and do the bends. The line from the proportioning valve to the rear was to long and I had to shorten it by making a loop. I don't think I would want to install them again, it was a pain.
solidGas is offline
Old 06-12-2007, 01:11 PM
dozierstang
The lines I got only needed a little tweeking. Everything else fit really good. I did not have a hard time at all installing my pre-bent lines. Same with my tranny lines and fuel. Only had to tweek to fit.
Old 06-12-2007, 07:17 PM
dnswwood
dnswwood's Avatar
Thanks for the replies people,looks likeI will end up bending some of my own.Did some checking around and your right its just as cheap to bend your own and get the fit you want.
A couple of questions sinceI dont have much experience with braking systems,does it matter ifI move the proportioning valveover tothefenderwall a little more as long as it stays below the master cylinder? and does it matterwhere the splitter for the rear brakes is as long as its on the rear end?
Thanks for any help
Jeff
dnswwood is offline
Old 06-12-2007, 07:22 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: dnswwood
A couple of questions sinceI dont have much experience with braking systems,does it matter ifI move the proportioning valveover tothefenderwall a little more as long as it stays below the master cylinder? and does it matterwhere the splitter for the rear brakes is?
Thanks for any help
Jeff
Depends, are you using a seperate proportioning valve or is it a splitter/valve-in-one? If they are seperate, it won't matter. But, if the valve and splitter are an all-in-one, yes it does make a difference as the proportion of pressure applied will be lower for the back. Usually 70% front 30% rear is the bias. Flip those and the car won't stop properly or will lock up the rears easily.
Disregard my response, I read that wrong. I thought you were asking does it matter which end you connect the rears into.
Derf00 is offline
Old 06-12-2007, 07:26 PM
dnswwood
dnswwood's Avatar
Thats okI re -read it and it didnt sound clear so I edited it lol
Jeff
dnswwood is offline
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake lines
