how to get torque converter off
Old 10-08-2007, 05:02 PM
mySAVIOReigns
mySAVIOReigns's Avatar
Default how to get torque converter off
I can't get the torque converter off the back of the engine so that I can mount it to the stand. It seems there are 3 bolts holding it on. I tried to get one off, and it started to "round" it off. I backed off, cause I don't want that to happen. I sprayed some PB Blaster before I left last night. Any tips?
It's a C4 on a 200ci engine
mySAVIOReigns is offline
Old 10-08-2007, 05:07 PM
Riverside66
Riverside66's Avatar
Default RE: how to get torque converter off
Use the correct socket and a 1/2 inch ratchet and you shouldn't have any problems. Are you going through the inspection plate area (under trans and between the trans and engine)? Using an open-end wrench is a No No on a bolt like this. These things are usually over-torqued, but should still be on there very tight. Isn't there four bolts holding the torque converter on the flexplate?
Riverside66 is offline
Old 10-08-2007, 05:08 PM
dodgestang
dodgestang's Avatar
TC is held to the flywheel with 4 nuts. You can only see them one at a time as the motor is rotated the flywheel and TC will spinaround so that each nut will clears the back of the block and become visible(they are on the oil pan side of the flywheel)
dodgestang is offline
Old 10-08-2007, 05:10 PM
mySAVIOReigns
::smacks head::
Ohhh! I am such an idiot. Now I see why my family says I have no common sense
Duh, I didn't even think about rotating it down to where it is accessible on the bottom. Thanks guys!
Old 10-08-2007, 05:48 PM
dcohen
dcohen's Avatar
wow, that was brilliant
lol, everybody makes dumb mistakes every once in a while
dcohen is offline
Old 10-09-2007, 08:40 AM
mySAVIOReigns
Well I got three off with no problem, but the fourth one is giving me fits. The problem now is that the torque converter turns when I try to loosen the nut. I propped up a peice of wood against it, but that didn't work. Any more brilliant tips? I could get someone to hold it, but seems dumb to have someone come all that way for one thing.
Old 10-09-2007, 09:06 AM
TexasAxMan
TexasAxMan's Avatar
Just wedge a screwdriver or something in the teeth of the flexplate. Other than that, you can get someone to hold the bolt on the front of the crank snout with a breaker bar, but that will require someone else, unless you have really long arms.
TexasAxMan is offline
Old 10-09-2007, 09:47 AM
boogerschnot
boogerschnot's Avatar
Or use a deep well socket and just turn it until the socket ends up against the bell housing and push.. Thats how I did it. Thats also how I tightened them back on when I put the motor back in.. Little hint,, buy some more torque converter nuts when you re-install..
boogerschnot is offline
Old 10-11-2007, 10:36 PM
petec
petec's Avatar
And all these years I have ben using an air impact with a u-joint and an extention to take these off.....I was missing all the fun.
I'll second the buying new nuts for the TC.
petec is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: how to get torque converter off
