351 stroker
351 stroker
I am looking to build a 393 stoker for my friends '83 Mustang, the car has a 351 in it now but has spun a couple of rod bearings and we will be using a different block.Right now we are looking to buy an Eagle street-strip complete rotating assemble. We want to know ahead of time if there are any clearance problems with the cam, as I want to use a kit with H-beam Eagle rods.We expect to have to do some notching of the block. I wonder if anyone has used these kits and what kind of glitches we may run into.
RE: 351 stroker
ORIGINAL: Heartbreaker
I do not think that the cam will be an issue with a 393.
The H beams will be much more compact than I beams. In our application I beams would have required clearancing.
RE: 351 stroker
Thank you for the info. Your under hood is great. I love these forums, I have been getting info from the 460 Ford forums about putting together a 429 for my new 69 fastback drag car, and I am always impressed how Ford guys are so willing to share info and help each other out. I have been running a 66 coupe with a 302 at our local drag strip for over 10 years now, and I have a blast beating the **** out of big block chevys. Keep up the good work dude. If you have interest in Hawaiian drag racing, check out mrp.org (Maui Raceway Park) You will see my name at the top of the Summit Pro points standings. john
RE: 351 stroker
Thanks for the info. I build a lot of engines, mostly chevys (as they always need it), and 302's for my own Mustang, but other than some stock rebuilds I haven't done very many 351's, but I'm learning fast how to make good power. john
[IMG]local://upfiles/37543/6A50647184BF41C9A32781DA2035C57D.jpg[/IMG]
Mustangs of Illinois
08-22-2015 10:00 PM
