66 coupe Auto trans Hangs in 3rd????
10-18-2007, 04:28 PM
I have a 66 coupe with an auto trans and it just started hanging in 3rd gear. I check the trans fluid with motor hot and in park appears to be ok. The car will shift 1 to 2nd and 2nd to 3rda smooth as possible, when you slow down it down shifts as it is supposed to it just wont shift from 3-4. Any help out there????
10-18-2007, 04:41 PM
RE: 66 coupe Auto trans Hangs in 3rd????
I'm no expert...
check your shift points..a modulator or something?
vaccum?
10-18-2007, 06:31 PM
well if its a c4 tranny (which it most likely is) then it only has 3 gears
10-18-2007, 08:22 PM
I agree with connor. The stock trans only has 3 speeds.
10-18-2007, 08:56 PM
The only four speed stock on a 66 was the four speed manual.
10-19-2007, 01:19 AM
Exactly what im thinking..I believe your problem is not one at all but rather a properly workign transmission.
10-19-2007, 02:30 AM
could be a aftermarket aod.. but asu all said most lickely a c4, only a 3 speed
10-19-2007, 09:56 AM
Yea bud, I think youre tranny is working just the way it should..
10-19-2007, 10:02 AM
Mach I Section Moderator
Brian, thank you you made me laugh, i was having a bad morning now im all better.
uedlose
The Racers Bench
10-01-2015 08:31 PM
mungodrums
09-28-2015 10:54 PM
Sixer4Life
09-28-2015 07:05 AM
2poor4u2
09-26-2015 11:08 AM
97SN95GT
09-13-2015 09:45 PM
