Cam question
Old 11-13-2007, 11:30 AM
silverblue66
silverblue66's Avatar
Default Cam question
I am making some mild mods to my c-code 289, and am looking at a k-code hi-po cam. is this a good cam? how is its efficiencey, drivability, performance, etc? What kind of increase from stock can i expect? How does it compare to a mild cam from comp, crane, etc? I want to use only ford parts on my car so I really dont want to go to an aftermarket cam. Also I have an autolite 4100 600cfm carb stock 302 4br intake and hi-po exhaust manifolds, with 2 inch exhaust.
Thank you
Kip
silverblue66 is offline
Old 11-13-2007, 12:37 PM
67mustang302
67mustang302's Avatar
Default RE: Cam question
If it's an actual k code cam, then it's not gonna be very efficient at all, especially by modern standards. If you're gonna go to the trouble of swapping cams you might want to seriously consider a good aftermarket camshaft. Vaveltrain technology has come a long way in the last 40 years. I know that comp makes modern versions of factory muscle cams. They have several different k-code replacement cams, so you might want to consider that as an option if you're trying to stay more true to form
67mustang302 is offline
Old 11-13-2007, 02:46 PM
Starfury
Starfury's Avatar
There is a hydraulic version of the hi-po cam available (I know Glazier's sells it) that supposedly works great. The problem with dropping a high-revving cam like that in a non-K code motor is that the stock rod bolts aren't going to stay together at the 7k rpm thata hi-pocam will gladly turn, given the right valvetrain upgrades (springs, screw-in studs).
If you're doing mild mods, a mild Comp Cams cam or Edelbrock Performer Plus cam will probably be fine.
Starfury is offline
Old 11-13-2007, 02:49 PM
jlg2002
jlg2002's Avatar
Good advice from 67, since you don't have a stock engine why go toa stock cam. The specs on the K code cam arent worth the effort IMO.
jlg2002 is offline
Old 11-13-2007, 08:13 PM
69FECoupe
69FECoupe's Avatar
I won't get into the new technology/old technology debate but since I did exactly what you are contemplating, I'll offer you my experience. Back in the mid seventies, I put a factory K-Code solid lifter cam in a 69 302 2V Mustang 4spd. I used a 600 Holley on an Edelbrock manifold,Hookers, and a 4.62 rear with Traction-Loc. I didn't swap the press in rocker studs or do any bottom end work. It ran great and sounded even better. I didn't twist it past 6800 and couldn't break it. Are there better performing components nowadays? perhaps but I have not heard an after market K-Code cam that sounds like the original.
69FECoupe is offline
Old 11-14-2007, 12:25 AM
67mustang302
The main reason the old school cams sound so good is from all the overlap. They didn't know how to get good power out of cams like they do today, so they went with what they knew, keeping both valves open together longer, and with long duration, so you got a healthy lope, and good scream at higher rpm. Modern cams that sound like the cams from the 60's are just absolute animals
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Cam question
