Lower Radiator Hose
Old 12-16-2007, 03:30 PM
Mustang629
Mustang629's Avatar
Default RE: Lower Radiator Hose
What kind of phone do you have? Those are some really nice photos!
Okay, here is what I have found:
Ron Morris makes a custom lower radiator hose for the stock radiator but I do not know the price:
http://www.ronmorrisperformance.com/05spec/index.html
I found many custom aluminum radiators for the 5.0 conversions but they seem to cost $500-$700.
I found a new brass/copper 3-row radiator for the 5.0 conversion in Mustangs Plus for $195.
http://www.mustangsplus.com/xcart/se...rch&page=1
Mustang629 is offline
Old 12-16-2007, 03:42 PM
Mustang629
Mustang629's Avatar
Will a 6 cylinder aluminum radiator work for the 5.0 conversion?
I noticed the 6 cylinder radiators have the proper locations for the inlet and outlet. The 6 cylinder is near the same physical size isn't it?
The newer technological advances in aluminum and more fins should allow more than enough cooling for a 5.0?
Old 12-16-2007, 04:06 PM
JMD
JMD's Avatar
We have a Northern aluminum radiator that we got off of e-bay that has left side botom hose placement... same cost as standard placement... about $300.00...
IMO the flow of the pump should not matter, just the hose placement.
JMD is offline
Old 12-16-2007, 08:46 PM
JamesW
Moderator
JamesW's Avatar
here's some info on installing an aluminum radiator in a 65-66...
http://www.midnightdsigns.com/Mustan...r_install.html
JamesW is offline
Old 12-17-2007, 08:16 PM
Mustang629
Mustang629's Avatar
ORIGINAL: Mustang629
I just found out that the 6 cylinder and 8 cylinder radiator are the exact same size and have the exact same number of rows. The only difference is the staggered inlet/outlets on the 6 cylinder radiator.
Also, the upper outlet has a slightly larger diameter on the 8 cylinder radiator.
Looks like I am going with the Mustangs Plus radiator for $200. It is a bolt on application meaning less work for me
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Lower Radiator Hose
