rockers
rockers
anyone know ratio i should go with on these GT40p's on my 289? 1.6 or 1.7? i also want to keep to pedestal mount unless i can get away with stud mounted for less or comparable as i got these heads with no 'studs' or rockers, i'm going to be running a comp 268 cam with a .456 lift and wanted to get the right ones. also are the 'studs' 5/16 or what?
RE: rockers
alright well, i'd like to go with 1.7 to increase lift to .485 but i can't tell on summit if these crane rockers come with the bolts to hold em down or not since i don't have these :|
RE: rockers
if you buy the crane 1.7 pedestal style roller rockers you can just bolt them right on. if you want "regular" roller rockers (in any ratio) you can buy a stud conversion kit that screws into the 5/16 holes in your heads and gives you a 3/8 stud sticking up.
the crane 1.7 pedestal style rockers are the same ones ford used on the cobra motors - they are good quality.
also, you can get away with using stock springs BUT your pushing things pretty close. money permitting i would upgrade to something that gets rid of those stupid exhaust rotators and adds a few pounds of seat pressure.
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
