1965 mustang gauge hookup
Hey all, im up against a wall I am replacing the gauges. How do i know which wires go to where on the back of the gauge cluster? How do I get this thing hooked up? Any suggestions as to where I should begin?
wiring codes
All the wires have color codes that can be followed on a schematic to the right place
Here are links by model year for every Mustang Wiring and Vacuum Diagram.
http://www.hammar.dyndns.org/wiring/wiring1964.htm
http://www.hammar.dyndns.org/wiring/wiring1965.htm
http://www.hammar.dyndns.org/wiring/wiring1966.htm
http://www.hammar.dyndns.org/wiring/wiring1967.htm
http://www.hammar.dyndns.org/wiring/wiring1968.htm
Bookmark your year for future use.
Ron
__________________
http://chris66dad.tripod.com/
A code 66 coupe
289 4v, Roller Rockers, Electric fan
Performer & 650 Edelbrock
MSD ignition
Tri Y into 2.25 Shelby side exhaust
T5 conversion
Hydraulic clutch
Granada Disks
Ron
__________________
A code 66 coupe
MSD ignition
T5 conversion
Hydraulic clutch
Granada Disks
Good point!
I changed to LED bulbs in the instruments cluster and I can see now!
They were 25 bucks but you will never have to replace them again, are twice as bright and fit into the original sockets.
Also a good time to repaint the pointers since you have it out too.
Here is the eBay person I bought from.
http://stores.ebay.com/HiPoParts-Man...QQftidZ2QQtZkm
i have new bulbs and plastic cover and I can see it perfectly well. has a lovely blue shine to it (i have the 64 type speedo). maybe it's a ground issue or your dimmer not working properly. I'd tried that first. mine work perfectly stock
Joolander
05-02-2016 02:28 AM
10-01-2015 09:11 PM
