Lower Ball Joint Replacement
Steering end links or tie rod ends, the lower ball joint is on the control arm and attaches to the spindle. You're gonna need a ball joint separator, the u shaped ones with the threaded stud work 10x better than the pickle forks.
You are talking about this right? Just want to clarify since there was some confusion.
If so it messes with your toe of the alignment so make sure it is put in almost exactly the same. Might mark on the sleeve how far in it is and then when you screw in the new one make sure it is on that mark or as close as you can get it.
That's it. I just finished putting them on. The rubber grease boot doesn't look like it's going to stay on the bottom part once the steering moves around but I'll have to check them after I drive. If the rubber boot comes off from the bottom piece how can I fix it so it won't come loose? Does that mean I screwed up?
Dragonus18
09-09-2015 01:21 AM
