Gauges
Gauges
Im installing custom gauges in the cockpit. Bezel has speedo, fuel level, oil pressure, volts, water temp. tach mounted on steering column. Im going to install 2 more gauges in the center console im building.
Question is what do you think are the next 2 most important gauges?
347 AOD carbed
thanks,
Dan
347 AOD carbed
thanks,
Dan
trans temp might not be a bad idea
air/fuel is a great idea but at $300...
fake...what does measuring vacuum tell me? and if my water temp is in check wouldnt my oil temp be ok as well? I cant see oil getting hot when water temp is good. But im a novice which is why I ask
thank you
Dan
thank you
Dan
Never connect it directly to the battery. The gauge will drain the battery even if the car is off. Connect the positive lead of the gauge to a switched power source. I would suggest a wire comming from the ignition switch that gets power when the switch is in the "ON" position.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
