tach with HEI distributor
thinking about buying a small tach to on my steering column, but i just put a HEI distributor in the car. how do i hook up the tach because the HEI distributor has the starter coil attached to the top of the distributor?
also i found a tach but it says only fits vehicle with distributor ignition, will this one work? or does that mean will only work with starter coil?
I have the about the same setup. My coil is marked as to which lead goes where. Considering it's an HEI, and you don't have the tach yet, the one connector that isn't being used would be for the tach. No resistor needed between the coil, and tach.
Tad is right, The "TACH" connection is right next to the "Ignition" terminal on the edge of the HEI cap.
The terminal is conveniently labeled...
Simply connect this terminal to the "Coil" wire on a typical aftermarket tach and you are good to go.
The purple wire is the "Tach" wire in this pic.
alright good deal, didnt know how hard or easy it would be. the HEI should be here today or tmrw (if they ship on the 4th) so i havent had a chance to look at it yet.
pictures would be nice if you got them.
thanks guys
thanks guys
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
