Fuel Pump Location
07-24-2009, 05:54 PM
Fuel Pump Location
Can anyone tell me how to access a fuel pump on a 1969 Mustang Coupe Grande for replacement purposes? Thanks.
07-24-2009, 06:54 PM
Quote:
Originally Posted by
Mesomorphman
It's on the left-front corner of the engine on V8's, and the center left side of 6 cylinder engines.
07-24-2009, 07:22 PM
Moderator
Well he could just follow the fuel line from the carb....I was thinking maybe the AC unit or something was in the way....
-Gun
07-24-2009, 07:42 PM
What is that thing that sits in the gas tank?
07-24-2009, 08:16 PM
Mesomorphman
It's the sensor that measures the fuel level.
07-24-2009, 08:26 PM
Okay. Found it. But how the heck do I get to it? If I have to take that radiator hose off, will I have to drain the radiator?
07-24-2009, 09:51 PM
Mesomorphman
Hmmm… I've never had to take a hose off to access the fuel pump. Unless you have some weird aftermarket hose…
07-25-2009, 10:27 AM
Two fuel lines and two bolts. You should be able to change it in 1/2 hour. Remove the old one, clean the mounting surface completely, put a dab of break in lube on the arm, use a small amoount of gasket adhesive on the gasket, and you are all set.
08-13-2009, 02:49 PM
I have a 1966 Ford Mustang 289, I would like to sheck the fuel filter to see if it is dirty,
Can you tell me where it would be located, Thanks Bill
08-13-2009, 04:21 PM
I am not 100% sure but I think the fuel filter is on the carb. Bronze color. You can follow the fuel line from the pump to it I think.
Correct me if I am wrong.
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
svfetter
10-05-2015 11:39 AM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
1966 ,
1969 ,
2005 ,
2006 ,
289 ,
66 ,
edge ,
filter ,
ford ,
fuel ,
location ,
mustang ,
pump ,
replacement ,
v8
