Outside rocker panel removal
I may start to remove my drivers out side rocker panel next, what is the best way to remove it?
Should I drill out the spot welds on the top and bottom seams, or just use my air chisel and run it down the seams like I did when I cut my floor pan off the inside rocker and frame rail?
Thanks,
Lynn
Thanks,
Lynn
It depends on how you want to fix it. Mustangs Monthly has an article that shows how to re-skin it or how to replace it. I'm still in the process of a full replacement and there are some issues with cutting it all off. Have a look at the mentioned articles and make your decision from there. jlg
jwog666
12-27-2021 08:09 PM
