Rear end question
Old 02-21-2011, 11:28 PM
Stangman70
Stangman70's Avatar
Default Rear end question
Hi guys, I recently bought a 9" rear that was missing a center section. It originally came out of a 70 mach 1. I have a 9" laying around but it is from a 76 t-bird, and I know nothing about it. All I do know about either rear is that the mach 1 rear has 28 spline axles and the t-bird is 31. My question is if I could use the center section from the t-bird in the mach 1 housing just by changing the gears.
Stangman70 is offline
Old 02-22-2011, 12:55 AM
001mustang
001mustang's Avatar
too late to follow your question.
you can use any 9" pumpkin in any 9" axle housing if axle is correct length.
axle bearings come in different flavors.
non-tapered axles can be cut and re-splined.
001mustang is offline
Old 02-22-2011, 02:10 AM
Stangman70
Stangman70's Avatar
So I could cut and respline the axles from the t-bird and put those and the center section into the other housing? Could I just swap over the center section using the 28 spline axles since they are already the correct length?
Old 02-22-2011, 03:02 AM
andrewmp6
andrewmp6's Avatar
The 3rd member won't work unless you change the diff in it to a 28 spline.Or look on curries website for 31 spline axles for that housing you have.
andrewmp6 is offline
GimpyHSHS
08-29-2015 06:30 PM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
ding56
08-14-2015 02:40 AM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: Rear end question
