leaky rear main seal
Old 07-05-2011, 02:30 PM
jimmy428
jimmy428's Avatar
Default leaky rear main seal
i believe my rear main seal is leaking. what can be done to help the leak? i do not want to pull the engine at this time. it will be properly fixed in due time, but i want to be able to deal with the leak easier for now.
bar's leaks rear main seal repair?
20W-50 or any oil thicker than 10W-40? if so, what do you recommend?
there is spotting in the driveway, not a huge leak, but enough to annoy. Thanks and as always, I appreciate the help.
jimmy428 is offline
Old 07-05-2011, 02:52 PM
mikeofwarr
mikeofwarr's Avatar
I had to replace one on my 73 Convert, 6 cyl, a long time ago. The seal came in two pieces and I just loosened the motor mounts and raised the engine just enough to get the oil pan off.
mikeofwarr is offline
Old 07-06-2011, 08:54 AM
69thunder
69thunder's Avatar
Sorry, there is no magic bullet. It will leak until the seal itself is replaced. Thicker oils and additives may slow it to some degree but it will not stop leaking. If you are mechanically inclined it really isn't that bad of a job to replace.
69thunder is offline
Old 09-10-2011, 08:51 PM
missouriman
missouriman's Avatar
hey guys im new here and was hoping someone could help me out , first i want to say sorry for cutting in on this thread but not sure how to get one started , I have a 1996 mustang gt, had blow by really bad, so other day i had the motor rebuilt, the shop that rebuilt it said the motor isnt the one that came out in it, anyway, got the car back and in 30 miles the seal started leaking again, took it back and they are working on it now but said they picked up 3 seals and non of them are the right one, so im wondering if differnt 4.6 motor take different rear seals or are they all the same, any help would be great thanks and again sorry for high jacking the thread
missouriman is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
Demodulates
09-18-2015 11:14 AM
09-16-2015 07:53 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: leaky rear main seal
