C 4 tranny mount removal
Old 08-26-2013, 05:06 PM
fb1371
fb1371's Avatar
Default C 4 tranny mount removal
can anyone give me instructions as to how to replace the tranny mount on my 66. I have just replaced the ujoints and would like to replace the mount as well. thanks in advance for the help. ( I had a vibration at around 50 mph on up and getting worse as I sped up. It did help greatly with the u joints replaced but still have some vibration so the mount is next.) for anyone that may also have an opinion here is how my vibration goes as I can describe it. going down a long hill and my car levels out on a coast at around 50 mph you feel the vibration but you dont have to gain speed to make it worse all you have to do is slightly touch the gas pedal a little and it will really vibrate and will instantly reduce when letting off the gas.
fb1371 is offline
Old 08-27-2013, 06:51 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
Support the trans with a jack, blocks of wood, ex-wife's photo albums, etc.
Drop the rear cross member and remove the trans mount.
Reverse on installation.
Sounds like a bent drive shaft maybe.
Check it for dents.
Boogie's_AutoRama is offline
Old 08-27-2013, 03:59 PM
fb1371
fb1371's Avatar
thanks Boogie, while I had it jacked up installing ujoints I cranked it and let it spin with rear in air and it started making a heavy loping vibration so I shut it down. no one was there that I trusted to do the same while I looked at what was happening. going to take it to my good mechanic and let him give it a go over. ( after I install trans mount)
fb1371 is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: C 4 tranny mount removal
