Rocker arm tightened all the way
Old 09-16-2011, 09:32 AM
dmaclaren
dmaclaren's Avatar
Default Rocker arm tightened all the way
So, I have Hydralic lifters as stud rocker arms.
When I used a cut out valve cover to check what I thought was valve lash, I found that all the nuts are 100% tightened all the way down.
I thought one had lash and I loosened it while running to the click/slap. Then tightened until it went away then 1/2 turn more. Well, unledd I put on another nut, it will loosen.
So as i didn't have one, I did 1/4 turns until it was all the way tightened like the other 7.
So, what am I missing here? Is this doing damage? Is this oaky? Am I robbing any HP or adding advanced wear?
I read a ton of doing this while running adjustment but these appear non adjusting.
Do I get 8 nuts and while running back off until lash then remove lash, 1/2 turn and then double nut?.. UGGGGGG
FYI, engine has 2500 miles on rebuild.
dmaclaren is offline
Old 09-16-2011, 09:37 AM
67 evil eleanor
67 evil eleanor's Avatar
Lifter issue?
67 evil eleanor is offline
Old 09-16-2011, 10:15 AM
JMD
JMD's Avatar
I am about 100% that all rockers for 69 are non-adjustable, these should be torqued to spec, no adjustment.
If you still have slack in the valve train you may have a lifter that is worn off at the base, (will have wiped the cam lobe) or you may have a collapsed lifter (collapsed hydraulically).
Could be a worn or broken rocker arm too.
JMD is offline
Old 09-16-2011, 11:40 AM
dmaclaren
dmaclaren's Avatar
I thought the non adjusting too. I'm good, there was no lash, turns out it's a exhaust leak but man it sounded exact. But, I wanted to question the 100% bolted down.
Old 09-17-2011, 07:26 PM
Randys66gt
Randys66gt's Avatar
You have a typical windsor, non adjustable studs that are pulling out!!!!
Randys66gt is offline
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
UrS4
09-30-2015 10:13 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: Rocker arm tightened all the way
