Bearings to improve steering wheel parking?
A co-worker was explaining that he was able to improve the parking-handling of his classic Mustang with some kind of real good bearings. I have a 1966 Mustang with manual steering. I don't want to go to a power steering (rob power, costly, I'm fine with the steering when moving). But I'd like for may wife to be able to park easily. Is there such a thing as an improvement to the bearings to provide easier steering when parking?
I see a ton of material on the web about improving steering on a classic Mustang. Often I'm not sure when it refers to the bearings or to some expensvie rack-and-pinion solution since I'm not all that knowledgable.
Would this be something I could have my machnic try for just a few hundred bucks?
A careful rebuild of your stock steering gearbox, with new bearings, seals, and careful setting of the preloads, not to mention filling it with new steering grease, will make a world of difference if it's a 40 year old untouched box.
This may be what he was referring to, a roller idler arm:
http://www.opentrackerracingproducts.com/idlerarm/
After install you may need a realignment to make sure the wheel returns to center after a turn.
Have you done the Shelby 1" drop? this also improves steering ease by putting the tires flatter to the ground and allowing a better range of alignment and it will need to be aligned to the shelby specs after doing. It's practically a free upgrade short of the alignment:
http://www.opentrackerracingproducts.com/droptemplate/
This is a good summary article of improvements you can make to the stock suspension and gives you a little more insight on design:
Jon
Jon
09-08-2015 11:50 AM
