I been trying to put my motor back together, but i am missing something that needs to be bolted to the motor, and i have no clue what goes where, i probably should used a camera with references, but didnt think about it at the time. i need a straight picture of the front of the motor with the water pump on.
thanks
or if someone has a part diagram where everything goes, that would help!
this picture is perfect, i have a gap behind the bracket for the dipstick and the motor - where i circled it
since you said you put the coil on the other side, so does that where the coil goes?
yes. the bracket goes under that dipstick tab. the coil on mine is an MSD blaster, it's just a little long and it wouldn't fit so i had to move it to the driver's side.
Here's another. It's wearing a car, so harder to see stuff. This one is stone-stock, other than the coil. The coil is in the correct place, although it's a black replacement, with Pertronix wires attached.
thanks for the picture, when Buckeye posted his pictures, i went to the garage to see if the coil bracket fit in there and it did.
so hopefully going to paint my motor this week, then going to order some stuff from CJ's since they are doing a 20% sale to dress up the motor
