Starter Still ingaging
Hello All,
I recently was sucesful in installing a HEI ingnition sytem in my 68 mustang.
However, after starting the engine for the second time, the started stayed ingaged while the engine was running. An awful noise I may add. And then I turn the key off, and it still ingauges. And then in less then ten seconds, the battery is completly dead. Any idea ofwhat it could be?
I did pull 12V power from a black wire on the keyed ignition, could that have something to do with it?
Thanks,
Mike
Thanks,
Mike
i would think that you tying into a keyed lead on the ignition would not really affect it, but is it possible that you may have made a faulty connection and crossed it or arced it with another terminal.
Or, you solenoid could be bad!
I would start with the connection on the ign switch though. since it started once you made that change.
Hello All,
Thanks,
Mike
Thanks,
Mike
If it doesn't stop, the relay is most likely bad. Give it a wop with a hammer and see if the starter stops. Either way a new relay is in order.
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
